i have an 03 F-150, 6-cyl. been having problems starting, found that fuel pressure was very low. I replaced the fuel pump and fuel filter two weeks ago. It has been driving fine for two weeks, however, it has been difficult to start a few times. This am it would not start. I checked the fuel pressure at the manifold and it was zero.
When the ignition is turned on, i can hear the fuel pump priming and then shut off. However, the fuel pressure reads zero.
I've checked the inertia/fuel shut off switch and it is fine.
Any suggestions or experiences would be appreciated
