massive issues with daily driver - Ford F150 Forum - Forums and Owners Club
Go Back   Ford F150 Forum - Forums and Owners Club > Ford F150 Forum - Help Zone - Ford F150 Problems, Complaints, and Solutions > 4TH Generation Ford F150 1992 to 1996 Ford F150 Trucks > Powertrain Engines, Transmissions & Differentials > 5.0L V8 Specific Topics
Notices
Reply
Thread Tools
  #1
Old 01-18-2017, 02:21 PM
comrade red xv2 comrade red xv2 is offline
Ford F150 Forum Newcomer
Gender: Male
Vehicle: 1993 f150 5.0
Color: red
Engine: 19921993 302 CID (5.0 L) V8 185hp 270lb/ft
comrade red xv2 is on a distinguished road
Default massive issues with daily driver
Firstly, hello everyone, I am new to the forum, and need some help with my truck.
Long story short, I am navy stationed in OK, and traded my d21 for this truck with a friend who was moving to California, as this beast wouldn't pass their emissions, so history on the truck is kind of spotty, here is what i know after a month of driving it:
At some point, it was a 5.7(?) when you run the vin, that is what the build was.
It has 206k miles, and overdrive trans.
In the cold it needs to be started a few times as it would cut off after a minute or so.
Sunday night, i filled up the rear tank, on my way home, the O/D light began flashing, and the transmission started jumping gears, and the engine started jumping revs, before finally shutting off and not starting again. Monday, i started troubleshooting and had no fuel pressure on the rail. So, since i could hear both fuel pumps priming, i replaced the fuel filter, now i have plenty of pressure, but the truck starts after a few tries, and then runs erratically, revving up and down, chugging, and dying. sometimes it runs for ten seconds, and sometimes, ten minutes. So, in trying to get it to my house, it kept dying when i would hit the brake, and somehow my friend got it home without the brakes. The distributor, plugs, and wires are all good, and i can find no vacuum leaks anywhere. I have unplugged the MAF (assuming it is the big plug on the left of the intake manifold where the hoses go in) the IAC, and EGR, with no change in how it runs. This is my first throttle body injection vehicle, if it was modern, or even carbuerated, i could keep troubleshooting, but it is cold outside and i am out of ideas.
Thanks for the help ahead of time,
Liam.
__________________
Ford F150 Forum | Ford F150 Forums | F150 Forum | F150 Forums
Sponsored links
  #2
Old 01-18-2017, 02:24 PM
Gender: Male
Color: red
Default
another issue (before all this, i just remembered) anything past half throttle, and the motor would cut out, and then back on at the original rpm (approx, i don't have a tach)
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1997 F-150 4.6l Driver Airbag problem cortiz509 Electrical 0 03-26-2015 09:23 PM
Driver side control bezzel Roy33 Body & Interior 1 10-02-2013 08:08 AM
Front driver wheel not spinning freely F150Housing 5.4L V8 Specific Topics 9 07-24-2013 02:27 PM
issues neisesjos 5.4L V8 Specific Topics 2 11-20-2012 07:26 PM
Interior Driver Side Door Light Switch joshwatts1@live.com Electrical 0 12-03-2011 01:57 AM
Advertisement
Powered by vBulletin® Version 3.8.10 Beta 2
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vB.Sponsors
= Copyright F150ForumZ.com a Gigathreads.com Network Site =Ad Management by RedTyger
