Ford F150 Forum - Forums and Owners Club
Go Back   Ford F150 Forum - Forums and Owners Club > Ford F150 Forum - Help Zone - Ford F150 Problems, Complaints, and Solutions > 6TH Generation Ford F150 2004 to 2008 Ford F150 Trucks > Powertrain Engines, Transmissions & Differentials > 5.4L V8 Specific Topics
Notices
Reply
Thread Tools
  #1
Old 09-23-2011, 11:06 PM
12NV 12NV is offline
Ford F150 Forum Newcomer
Gender: Male
Vehicle: Ford F150
Color: charcoal Grey
Engine: 20042008 330 CID (5.4 L) V8 300hp 365lb/ft
12NV is on a distinguished road
Angry 2005 F150 5.4 exhaust problems!!!
I have spent the last two nights replacing the exhaust manifold gaskets on the right side of my truck only to find that wasnt the problem. I just developed the problem after pulling my new camper for the last couple weekends. It sounds just like the doughnut is out of the passenger side exhaust manifold. I start it up and there is a terrible sounding (what I think is some sort of exhaust leak) coming from the passenger side engine or down below, then it seems to get less as it warms up.... I changed the exhaust manifold gaskets because I thought that is what it was. The local parts store says there isnt a doughnut between the exhaust and the manifold so I am at a loss for words or thoughts. I am ready to back it out of the garage and lite a match to it. I cant stand the sound of it any longer... Any advise as to what it is would be greatly appreciated...
__________________
Ford F150 Forum | Ford F150 Forums | F150 Forum | F150 Forums
Sponsored links
  #2
Old 09-23-2011, 11:19 PM
GT's Avatar
GT GT is offline
FORD F150 FORUM
Gender: Male
Vehicle: Ford F150
Color: Blue
Engine: 2010-2013 379 CID (6.2 L) 2V V8 (SVT Raptor) 411hp @ 5500rpm 434lb/ft @ 4500rpm
GT will become famous soon enoughGT will become famous soon enough
Default
I'm not certain if there is a doughnut between the exhaust manifold and the exhaust on 2005 models, but the first thing I would do is if the sound is loud, let the truck cool off. Then start it up when the sound is loudest. Get under the truck and place your hand near the connection. You will definitely feel the exhaust leaking if that's where it is coming from.
Also, check the for a loose connection there, and tighten if needed.
__________________
  #3
Old 09-24-2011, 09:39 AM
Gender: Male
Vehicle: Ford F150
Angry
Hey yeh, thanks, I have done that, and really cant feel any leaks. I was wondering, is there some kind of valve in the exhaust that would be leaking or making some kind of noise and could use replaced? I see some kind of deal in the side of the exhaust pipe and was wondering if that could be leaking or something. It is cold here this morning so I am thinking of trying to plug the rear exhaust with something and see if I can see anything by doing that... Thanks again... Any further help would be appreciated.. One guy I know said he thought it sounded like I blew a spark plug out of the motor, but I think it would run sluggish if that was the case? But dont know?!?!? Thanks again.
__________________
  #4
Old 09-24-2011, 12:29 PM
GT's Avatar
GT GT is offline
FORD F150 FORUM
Gender: Male
Vehicle: Ford F150
Color: Blue
Default
You could indeed have a loose spark plug. I've seen the insulator come loose before. Rare, but it happens. That's easy enough to check.
__________________
  #5
Old 12-13-2011, 11:25 AM
bullet2011 bullet2011 is offline
Gender: Male
Vehicle: Ford F150
Color: dark grey
Engine: 2011 302 CID (5.0 L) 4V V8 360hp @ 5500 rpm 380lb/ft @ 4250rpm
bullet2011 is on a distinguished road
Default
So if you dont already have it fixed, i have repaired a few of these. Always replace the manifold to they seem to crack and not be able to be seen or warp. Also once you have it back together the connection to the down pipe likes to leak. Most times after repalcing a manifold i clean the pipe going down and apply a small amount of antisieze to help seal. also you need to drop boht sides to realign correctly. I have seen may poeple disappointed casue they thought there was still a leak and it was just the connection to y-pipe. In some sever case you need to tighten it and let it warm up then re tighten and if keeps leaking take long bar and place adjacent to where the doughnut would go and hit it with a large hammer. Seems to also help it seat. Hope this all helps
__________________
  #6
Old 11-29-2013, 04:38 PM
Donnie LaCroix Donnie LaCroix is offline
Gender: Male
Vehicle: 2001 F150
Color: white
Engine: 19992003 330 CID (5.4 L) Triton V8 260hp 350lb/ft
Donnie LaCroix is on a distinguished road
Default
Had same problem on the same side of engine had to replace entire exhaust manifold got part from car quest and solved problem
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
2005 F150 Service Manuals mrstewcrew Ford F150 Parts for Sale - Trade - WTB. 1 09-16-2011 12:46 PM
Advertisement
Powered by vBulletin® Version 3.8.10 Beta 1
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
vB.Sponsors
= Copyright F150ForumZ.com a Gigathreads.com Network Site =Ad Management by RedTyger
